سلمان غازي
سلمان غازي
Sep 3
Does anyone feel that the idle vibration of the 2024 Macan S is a bit much? Just got the car, over 100 kilometers on it, and sitting inside feels shakier than my 4-cylinder BMW... Anyone else feel the same?
Comments( 6 )
سلمان غازي
سلمان غازي2024-09-04 18:44
I got tricked, thought a 6-cylinder engine would be smoother.
نايف احمد
نايف احمد2024-09-04 11:41
It's common with this machine; it works better when it's frequently used.
عبد العزيز ظافر
عبد العزيز ظافر2024-09-04 11:32
The 90-degree angle in the EA839 engine is normal.
سلمان غازي
سلمان غازي2024-09-04 09:28
Should I add fuel additives...?
سلمان غازي
سلمان غازي2024-09-04 09:27
I haven't been there. It's a new car, and I'm using 98 fuel. The idle vibration feels stronger than my BMW...
حسن طموح
حسن طموح2024-09-04 01:34
The GTS is also a bit shaky! Adding Sinopec 98# fuel helps a bit. Have you been to the 4S shop?
I have a 2018 GS7, and the engine vibrates a bit when idling. There's also a slight ticking noise when driving, which started recently. Can anyone help me figure out what might be causing this?
When the car is idling, it feels like it's shaking, but when I shift to neutral, it doesn't. Does anyone know what might be the reason?
When driving a 206 with a 1.6 automatic transmission, whether on the highway or at low speeds, the engine noise becomes very loud once the RPM exceeds 2800. There's a buzzing sound inside the cabin that is even louder than the wind noise—it's really loud! When the car is idling after warming up, there's a noticeable vibration if you hold the steering wheel or sit in the seat. What could be causing this? Looking for guidance from experts!
I just drove my new 2024 380 Luxury for over 100 kilometers, and I'm feeling vibrations in the accelerator pedal when I accelerate. What could be the issue? Do any fellow car enthusiasts experience this too?
Is anyone else experiencing noticeable idling vibrations? 😂 Just got the car, and it drives smoothly, but the idling vibrations are quite strong. Is anyone else having a similar issue?
Is it normal to feel slight vibrations when sitting inside a Patrol 4.0 at idle?
Does the Peugeot 3008's automatic door lock still allow the doors to be opened from the inside? Is this normal? What solutions are there? Otherwise, it really doesn't feel secure.
I noticed occasional vibrations in my Murano at around 20,000 km, and the vibrations don't last long. When I went to the dealership for maintenance, they mentioned that they could replace the mid-section improvement part with a bracket for free. Has anyone had this replaced? How does it feel after the replacement?
Does anyone feel the car shakes a bit noticeably at speeds over 120? Could it be because of the hard seats? I have a 2.0 Macan. Any brothers with the same feeling? Let's chat.
Porsche Macan
Porsche MacanKWD 15,400 ~ 32,100Diesel & Gasoline & Petrol
