Why won't the electric sliding door lock properly? I have to press it with my hand to fully close it.
Why won't the electric sliding door close properly? I have to press it with my hand to get it to lock.
The FJ keeps showing that the door is not closed. Pressing the lock button makes it beep continuously. Manually locking it works, but it still shows that the door is not closed.
My M7's electric right middle door isn't working. It opens a little, and if I press it again, it opens a bit more, but it won't close completely. Experts, what could be the reason for this?
4Can the sliding door of a Previa be converted to electric?
5The side electric sliding door of the Multivan can open, but it doesn't respond when closing. What could be the reason?
6What could be the issue with the electric sliding door of my Volkswagen Sharan not fully opening or closing?
7Why do I feel that the soft-closing mechanism on the rear door is less sensitive than the front door? With the same amount of force, the rear door doesn't close properly. Do you guys experience this too?
8Why does the car beep three times when starting, like the sound when a door isn't closed properly?
9Why won't the right door open suddenly? Is it the child lock? Where's the child lock switch?
10Even with the clutch fully pressed, the car still won't start.
