سلمان نور دين
2022-07-30 10:10
Hi everyone, could you please help me with how to use the projection feature on the 2019 flagship MPV? I've been trying for a while but can't seem to make it work. Also, the car system doesn't have a built-in navigation system.
عمر فاطمة
عمر فاطمة2022-11-04 17:14
I will buy your car.
Hi everyone, how do I adjust the headlight height on the 2017 GS7? Please help 😭😭
Hello, does your car's gear lever wobble? Also, can the side mirror folding feature be enabled in the system after locking the car? When I try to turn it on, it switches back off by itself.
I installed a new large-screen navigation system today, and after installation, the center differential lock light is on, the engine warning light is on, and the traction control light is on. What's going on? Help!!?
Hi everyone, can the phone navigation be connected to the V40 via Bluetooth if the original car doesn't come with a navigation system?
Hi everyone, when replacing the original navigation system of a Chinese-spec 93 with a used one, the speedometer isn't working. What could be the issue with the fault code?
I'm considering getting a used car, but the headlights seem to be halogen. Can anyone share their experience with these headlights? Also, is there a solution for the CarPlay system?
Why doesn't my 2021 Dream Edition come with a built-in navigation system?
When connecting Cyrus to Baidu CarLife, the navigation voice is too low, and the radio volume is too loud, making it hard to hear. How can I increase the navigation volume? The volume button doesn't seem to help.
Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
