Does anyone know where to buy rear shock absorbers?
How does the C40's variable damping shock absorber chassis perform?
Do any of you with the old 2012 model of Changan Yuexiang have issues with rear wheel shock absorber top corrosion and rust, leading to the shock absorber falling off? If you do, please type 1, thank you.
4Hey guys, how much does a pair of original V97 shock absorbers cost, and where can I buy them?
5Looking to purchase two rear shock absorbers, removed from a modified Vito.
6Looking to modify the shock absorber, does anyone have the wiring layout diagram for this car?
7Does anyone know if the shock absorbers for the 2.5 imported Koleos are compatible with those of the X-Trail?
8Has anyone here ever changed the front shock absorber top mount on an Ertiga by themselves? Is it possible to replace the front shock absorber top mount without removing the shock absorber itself? How do you get the top mount off? Any guidance would be appreciated. [Embarrassed face]…
9Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
10Why is my car's rear shock absorber leaking oil? Is this covered under warranty?
