What's the model for the high and low beam bulbs of a Liana? Anyone knows? 😊
Hi guys, does the 2017 GS7 1.8T have halogen bulbs or xenon bulbs for the low beam headlights?
Can I replace the low beam bulb on a 2010 S40 myself if one is not working?
4How do you turn on the high beam for the 206? The low beams can be turned on and the high beams can be activated by pulling the switch back, but it can't be pushed forward. What's going on?
5Suzuki Liana 2013 model! Why do all the lights work except the low beam? Where is the low beam fuse located...
6Hi everyone! Could anyone tell me where the low beam fuse is for a 2013 Liana? All the lights work fine except for the low beam. Does anyone know what the issue might be...?
7Is the headlight of the 2019 Changan Alsvin automatic a combination of low and high beam, or are they separate? I'm thinking about changing the bulb recently!
8Does anyone know why the high beam and low beam headlights keep breaking?
9I replaced a pair of LED bulbs on my car, but now the low beam and high beam look the same. Any tips to adjust them to be lower?
10For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
