محمد عل
محمد عل
Jun 30
Is the fuel consumption for the 2009 Liana 1.6 automatic reaching 10 liters per 100 kilometers because of a faulty oxygen sensor or carbon canister purge valve? I've checked the spark plugs and ignition coil, and there are no issues. Any advice from the experts?
نايف عبد لطيف
نايف عبد لطيف2021-06-19 23:35
Excessive carbon buildup!!! Last month, when I went back to my hometown, the mechanic asked me to add a can of carbon cleaner. Then I drove back on the highway and continued with my daily commute, and the fuel economy improved! You might want to try it; mine is also an 08 automatic.
خالد هاماوي
خالد هاماوي2020-06-30 22:56
This issue might be causing it. If there's a problem with the oxygen sensor, it could lead to high fuel consumption. I suggest getting it checked out and maybe clean the carbon deposits as well.
When coming to a stop, the idle speed suddenly drops and it feels like the car is about to stall. This occasionally happens when shifting from D to P while stationary. I've replaced the spark plugs, ignition coils, injectors, high-pressure fuel pump, PCV valve, carbon canister solenoid, air flow sensor, and engine mounts. I've also cleaned the intake carbon deposits and combustion chamber carbon deposits. The problem still exists. Can anyone help me figure this out? [crying][crying][crying][crying]
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
After a major maintenance on the 2006 Accent 1.4 manual, the spark plugs, carbon canister solenoid, and throttle have been replaced, and the fuel injectors have been cleaned. With the fuel price at 7.91, it's costing 0.9 per kilometer. Is this normal? The oxygen sensor is fine!
Recently, my fuel consumption has suddenly increased significantly. I suspect it might be the carbon canister purge valve. How should I check it? Can any experts help out?
The fault code shows two P0420s, one yellow and one red, both indicating the first bank. Is it the catalytic converter that's faulty or the oxygen sensor?
The car is a 2015 model and has run 99,000 kilometers. The warning light turned on, and you replaced 4 ignition coils and 4 spark plugs. After some time, the light came on again, and the engine shakes when starting, but it's still drivable, though the light remains on. What's causing this issue?
Hi everyone, can anyone tell me where the carbon canister solenoid valve is located in the Territory? A picture would be great. Thanks!
