avatar-image
فهد بهاء
Jul 25
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
خالد حمدان
خالد حمدان2023-09-06 12:30
Is the idle speed still unstable, with the RPM fluctuating up and down occasionally? 😬
حسن عزيز
حسن عزيز2023-09-02 09:36
I encountered this issue after replacing the carbon canister, and it shouldn't be an engine mount problem. Now I suspect it might be a timing issue.
مدرسي محمد
مدرسي محمد2021-08-04 12:19
The engine mount might be loose.
حسين طلحة
حسين طلحة2021-07-26 12:22
The engine mount can be replaced.
Is the fuel consumption for the 2009 Liana 1.6 automatic reaching 10 liters per 100 kilometers because of a faulty oxygen sensor or carbon canister purge valve? I've checked the spark plugs and ignition coil, and there are no issues. Any advice from the experts?
I have a 2007 Touran, automatic 1.8t. It jerks noticeably during acceleration. When idling while parked, the RPM intermittently drops by 100-200, and the car lights dim. What should I do? (I've previously cleaned the fuel injectors and throttle body.)
Hello fellow car enthusiasts, have any of you cleaned the throttle body before? I've heard that cleaning the throttle body on an MG3 is quite a hassle, taking up to 5 hours and costing 500 bucks.
The car is a 2015 model and has run 99,000 kilometers. The warning light turned on, and you replaced 4 ignition coils and 4 spark plugs. After some time, the light came on again, and the engine shakes when starting, but it's still drivable, though the light remains on. What's causing this issue?
The engine malfunction light on my 2010 City recently started flashing. Diagnostic code 14 indicates irregular misfires. I've replaced the spark plugs, ignition coils, and cleaned the fuel injectors, but the issue still occurs intermittently. Every time the light flashes, I restart the engine and the issue disappears for a while before reappearing. Any knowledgeable experts or fellow car enthusiasts have any advice on how to handle this issue?
The dashboard shows a warning light, and when checked with a computer, it indicates an ignition module issue. Should I replace the ignition coil? There are no problems when driving normally.
