سعود بوتفليقة
Aug 10
For the 2011 Suzuki Liana, if you're getting a catalytic converter fault warning, there are a few things you can consider. First, you might want to confirm the diagnosis with another mechanic to ensure it's indeed the catalytic converter that's the issue. Sometimes, other components like oxygen sensors can also trigger similar warnings. If replacing the catalytic converter is necessary and the cost quoted is over two thousand, you might want to compare prices from different repair shops or consider aftermarket parts, which can sometimes be more affordable.
My catalytic converter is poisoned. Can any experts recommend a cost-effective vendor to replace it?
If you're looking to buy a pickup truck that is both stylish and fuel-efficient, you might want to consider brands like Haval or GWM. They are known for their appealing designs and good fuel economy.
4Fuel not getting through, no power, engine warning light is on. What's the situation? Is it the fuel injector or the catalytic converter?
5Is it true that all used 2019 Changan Yuexiang automatic models are from Liandongyun? How can you tell if the catalytic converter has been tampered with?
6I want to convert my automatic Lancer to a manual. Can someone please give me a wake-up call!
7You can try checking online platforms like Amazon or eBay, where you might find a variety of tire sizes, including 245/60R20. Additionally, consider visiting specialized tire shops or larger automotive supply stores in your area, as they might have a wider selection. Sometimes, contacting the tire manufacturers directly can also help you locate a dealer that stocks the size you need.
8If you don't want it, can you transfer the order to me?
9Have any fellow car enthusiasts encountered a situation where the catalytic converter has minor cracks, causing occasional exhaust emissions to go uncatalyzed and triggering the emission warning light? The mechanic mentioned this. I regularly use Carpol's catalytic converter cleaner, Liquid Gold, etc., so there shouldn't be a carbon buildup issue.
10The engine warning light is on for my 2019 car, and the diagnostic says the catalytic converter is aging. What should I do? Do I need to replace it with a new one?
