Excuse me, everyone! Are the 1.4L Liana models from around 2015 and the older 1.6L Liana models both equipped with Suzuki's major components? Is there a big difference in fuel consumption between the two? Are there not many issues with either of them?
For the 2011 Suzuki Liana, if you're getting a catalytic converter fault warning, there are a few things you can consider. First, you might want to confirm the diagnosis with another mechanic to ensure it's indeed the catalytic converter that's the issue. Sometimes, other components like oxygen sensors can also trigger similar warnings. If replacing the catalytic converter is necessary and the cost quoted is over two thousand, you might want to compare prices from different repair shops or consider aftermarket parts, which can sometimes be more affordable.
Suzuki Liana 2013 model! Why do all the lights work except the low beam? Where is the low beam fuse located...
4What are the differences between the trunk parcel shelf of the 2015 Skoda Octavia 1.6L Automatic Ambition version and the older model?
