سلمان قنصوح
سلمان قنصوح
Nov 29
To set the air conditioner so that the compressor does not start and only natural or engine heat is provided, you need to: 1. Turn off the AC button, often labeled as "A/C" on the control panel. This will prevent the compressor from activating. 2. Set the air circulation mode to "vent" or "fresh air" to allow outside air to enter the cabin. 3. Adjust the temperature control to your desired level. For natural air, keep it neutral; for engine heat, adjust it towards the warmer side. 4. Adjust the fan speed to control the flow of air. These steps should help in using the ventilation system without activating the AC compressor.
خالد أنور
خالد أنور2024-11-29 13:37
When the water temperature rises in winter, you can turn on the external circulation to use the engine's warm air. No other operations are needed. 😊
أحمد خلف
أحمد خلف2024-11-29 12:27
Shout at the car system, "Turn off the AC."
فهد سعيد
فهد سعيد2024-11-29 10:15
In the car's system, set to turn off the AC.
20
What could be the issue if the air conditioning compressor keeps running even when the AC switch is properly turned off? Does anyone know?
When the self-drying function of the unit's air conditioner is activated, will it start after locking the car regardless of whether you turn off the air conditioner before turning off the engine or just turn off the engine and leave the car directly?
To activate the cruise control on the MX-5 NC, first make sure you're driving at your desired speed. Then, locate the cruise control button on your steering wheel or stalk and press it to turn on the system. Once activated, you should see a cruise control indicator light on your dashboard. Adjust the speed using the "Set" or "Resume" buttons as needed.
The 2008 model doesn't have automatic air conditioning or physical buttons for the AC, making it hard to adjust to a comfortable setting. Frequently using the screen to adjust can be distracting. Do you have any good solutions for this? Also, it's been raining a lot recently, causing more fogging. Turning on the defogger feels like hot air, and when you turn it off, you need to adjust the AC again. 🤔
The low-pressure pipe is frozen, and the air conditioner isn't blowing cold air. I've already replaced the expansion valve, condenser, compressor, and left servo motor, but it's still not working. Does anyone have a good solution?
Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
The issue with the cruise control not holding could be due to several reasons. While the indicator light on the dashboard shows that the cruise control is activated, it might not maintain the set speed.
To turn on the heater without the AC light coming on, you usually need to adjust the settings on your car's climate control system. Make sure that the AC button is turned off. If your car has an automatic climate control system, try switching to manual mode and adjusting the temperature and fan settings manually. If the AC light still comes on when you activate the heater, it might be due to the car's design to dehumidify the air, in which case you may need to consult your vehicle's manual or contact a service center for further assistance.
Lexus ES
Lexus ESSAR 197,915 ~ 275,697Gasoline & Hybrid
