Is the vibration noise when the wiper of the new ES200 reaches the far left side related to the glass oil film? Does anyone else have a similar issue?
After reaching a speed of 60, there is a constant hissing sound from the right rear side in my Arrizo 3. Is this due to wind resistance caused by a design issue, or could it be something else? Has anyone else experienced this problem?
I've been hearing a strange noise from the left side of the dashboard when I press the accelerator in the morning. It feels like a vibration. Have any of you experienced something similar? I'll upload a video next time.
Do you hear a sound like two wires colliding under the front left side of the dashboard when driving your Hyundai Reina on bumpy roads? It seems to be related to the steering gear. I've checked the chassis multiple times but couldn't find the issue. Have any of you experienced this problem?
4Is anyone else experiencing noticeable idling vibrations? 😂 Just got the car, and it drives smoothly, but the idling vibrations are quite strong. Is anyone else having a similar issue?
5When driving at high speeds, there's a ticking noise from the driver's side window that sounds like raindrops hitting the glass. At first, I thought it was raining, but it wasn't. The right window is fine. The noise disappears when I lower the window. Could it be caused by the window seal? Has anyone else experienced this? How did you solve it?
6Four years, 40,000 km, 1.5T F56. There's noticeable shaking and noise at idle. Is this common for everyone? I bought it second-hand, so I'm not sure how it was when new. Also, when driving on rough roads, there's noise from the left and right side windows. When the windows are down, there's no noise. I suspect it might be the frameless doors causing the glass to rub against the body. Does anyone else experience this?
7Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
8What's causing the creaking sound from the chassis when I get out of the car in the garage? The echo in the garage makes the sound louder. Has anyone else experienced a similar issue? I have a 2021 model that I've driven for 20,000 km over two and a half years. When parking, I stop completely, shift to neutral, engage the electronic handbrake, then shift to park, turn off the engine, and get out. That's when I hear a creak from the left rear side.
9Help needed! I have a 2017 model 95. With summer here, there's white smoke coming out at startup, but it goes back to normal after a few seconds. There's no lack of oil or water, and the computer diagnostics show everything is fine. I've been to several repair shops, but no one has found the problem. Has anyone else encountered a similar issue?
10Is the vibration noise when the wiper of the new ES200 reaches the far left side related to the glass oil film? Does anyone else have a similar issue?
