فهد قاسم
Nov 28
I bought an ES200, and the designer made an unusual choice by placing the only USB port on the surface of the center console. It's easy for the USB to get damaged by hard objects. Why not put the USB in the armrest box? Also, I want to ask fellow car enthusiasts if there's a way to convert the charging port with the lightning symbol into a USB port that can play music (I tried using a converter, but it couldn't play music).
How do you play USB music in this car?
Can the LinkTour Yun Kuanyue Xiang play music from a USB drive?
I have a 2014 used XV, and the USB port in the armrest doesn't recognize P3 and P4 USB drives. The DVD also can't play videos. I don't have the manual, so I'm not sure if this navigation unit doesn't have these functions or if there's a malfunction.
4The USB port in the armrest of a 2012 GLS can't charge your phone. Are there any other places to charge your phone?
5What should I do if I can't use the USB port to play music?
6Can the 2018 Renault Koleos play lossless music from a USB drive?
7Why can't I play music from a USB on my Chery Jetour X70 Plus?
8Can the Cetus car play music online, or can it download apps to play music, or is it only possible to use a USB drive?
9Is your 2013 Kia Sportage unable to recognize the USB drive and play music?
10The 2020 model only has one USB port. If you plug in a USB drive to listen to music, you can't connect the car kit. The USB extension ports you bought aren't working, and the USB in the armrest cigarette lighter also doesn't support USB drive for music or connecting the car kit. Do you have any suggestions for using both the USB drive for music and the car kit simultaneously?
