فهد صدام
2024-10-14 02:38
Hello everyone, may I ask if adding ambient lights and replacing the triple-beam headlights on the Lexus ES300h will cause any noise? A lot of people online say that after disassembling the ES, there will be noise. I would really appreciate your advice! Thank you! 😊😊😊
Comments( 8 )
سعود ميسور
سعود ميسور2024-11-12 23:43
I installed the ambient lights and replaced the triple-eye lights. No issues, right?
سلمان زكريا
سلمان زكريا2024-11-12 12:17
Why not buy the Zhenxiang [I Want Quiet] model?
سلمان صلاح
سلمان صلاح2024-11-12 09:50
1. Actually, there's no need to change it. The three-eye lights aren't much brighter than the single-eye ones. I adjusted the low beam height myself, and now it's quite OK! The original low beam center height is 71 cm, with a downward angle of 1%. Find a flat parking lot and adjust the light's lower cutoff line at a distance of 5-6.5 meters from the wall to 66 cm (the factory height is only 54 cm). After trying multiple times, these are the final figures I got. 2. If you must change it: Replace all the clips on the door panel (even if it's at your own expense), and make sure to closely watch them install the wiring correctly inside.
فهد إسحاق
فهد إسحاق2024-11-11 16:33
It completely depends on the master's craftsmanship.
محمد هشام
محمد هشام2024-11-11 14:11
No one can say for sure. It's best not to make any changes, especially to the headlights. If you modify the headlights and the car catches fire, insurance might not cover it. My friend's car had this issue.
سعود أيوب
سعود أيوب2024-11-08 21:51
Remember one thing: don't be stingy with the labor cost for dismantling the interior.
سعود رامي
سعود رامي2024-10-14 10:48
No noise detected after temporarily removing the door panel for car wrapping.
عبد العزيز زيد دين
عبد العزيز زيد دين2024-10-14 06:09
It depends on the skills of the installer.
I've heard that the 2019 V40 has 7-color ambient lighting. But I couldn't find any pictures online. Can someone please take a picture of the night effect? I'd really appreciate it.
Does anyone know if adding ambient lights to a 2012 Peugeot 508 causes any rattling noises? Thanks in advance!
If you're deciding between the 2022 Defender and the 2018 or 2019 Range Rover, here are a few things to consider. At 34, if you need a car that makes a statement and has always dreamed of the Range Rover, it might fulfill that childhood aspiration. However, if you're concerned about unwanted noises and have a bit of OCD, newer models like the 2022 Defender might have fewer issues in that regard due to advancements in manufacturing and technology. The Defender also has a rugged and modern appeal that many people appreciate. Consider what aspects are most important to you: the prestige of the Range Rover or the contemporary features and potential reliability of the Defender.
Is there anyone here who bought the GS4 Max in 2024 and can share their experience? I just test drove it a few days ago and really liked it, but the online reviews aren't very positive. People are saying there are a lot of strange noises and minor issues, and that rust is a big problem. How does it compare to the Nissan Qashqai?
Lexus Lexus ES
Lexus ESAED 193,825 ~ 270,000Gasoline & Hybrid
