عبد العزيز نظيف
2024-08-09 14:12
Could you recommend a car light? I feel like my current ones aren't bright enough.
حسين أم
حسين أم2024-11-21 11:51
I checked the forum and found that not many people are modifying their headlights. I'm also considering whether to upgrade to projector lenses or switch to tri-beam lights.
I feel like the headlights aren't bright enough, especially the high beams. Do any fellow car enthusiasts know of any parts I can replace them with?
The gear shift light for the 150 isn't on. Could it be because a button wasn't pressed, like the ones for P, R, D?
Hi everyone, I'm looking to upgrade the halogen headlights on my 2014 Yizhi to LED ones because they're not bright enough. Any good recommendations? Thanks!
Does anyone feel that the headlights of the Yaris X are not bright enough? Has anyone modified the headlights, and are there any compatible headlights available now?
Hey folks, are your car lights bright enough? I'm thinking about changing mine because they don't seem bright, but it looks like I have to remove the entire headlight to do it. Has anyone done this before? Any advice?
I bought a used 2018 Peugeot 3008 and feel like the halogen lights aren't bright enough. I replaced them with LED bulbs, but the light is still scattered and not good. Could you suggest what bulbs I should use? Also, does the original car come with projector lenses?
Can the daytime running lights be replaced separately? I modified the headlights, and it seems like the daytime running lights got damaged; their brightness isn't enough. It's a 2009 model.
Which engine oil is cheap and good for Nissan Sunny? Could you please recommend one?
I'm driving a 2013 Sunny with a manual transmission, high trim. The halogen lights really don't seem bright enough. I checked on Pinduoduo, but I'm hesitant to buy from there. Has anyone bought lights from there? Can any of you guys recommend something you've used? Driving at night is tough; oncoming high beams make it hard to see anything. 🙈 Can you recommend some good combined high/low beam lights?
Lexus Lexus ES
Lexus ESAED 193,825 ~ 270,000Gasoline & Hybrid
