حسن قابوس
2024-12-02 17:48
Has anyone else noticed a significant increase in engine noise after switching to Mobil Silver oil for the first time on their 2022 Levin Hybrid?
علي سالم
علي سالم2024-12-03 05:04
I just switched to Mobil Black Gold today and didn't really feel any difference. Qualified engine oils from reputable manufacturers shouldn't have noticeable differences. The original engine oil from the 4S shop is quite average.
When driving at low speeds and turning the steering wheel, the 2014 XV experiences significant body vibration and loud noise. However, this issue does not occur when the car is cold and has just started. I want to know what the reason could be? Does anyone else have the same situation?
When you start your 2019 model car and turn on the AC for the first time, you hear a noise like the fan suddenly stopping. What's causing this? It only happens once and then works normally afterwards.
Hey car enthusiasts, does anyone else notice a squeaking noise with the ID.3 brakes? Especially a "squeak" sound.
Does anyone else experience wind coming through the headliner when the AC is on (especially when the fan speed increases)? I can feel a noticeable draft when I touch the driver's side seal. There's also a whistling sound when the windows are closed. Is there a car owners' group? I'd like to join.
Hey guys, I have a 2019 Kicks. When I'm waiting at a red light and switch to N gear, then back to D, the acceleration feels noticeably slower. Has anyone else experienced this?
I have a 2022 model Roewe RX5 MAX 1.5T. When I step on the gas in reverse, there's a "clack" sound. If I don't press the gas while reversing, there's no sound, but as soon as I do, there's a loud and very noticeable "clack" noise.
Automatic parking makes a creaking noise when I press the accelerator to start. How can I fix this? It's not yet time for the first maintenance.
When will the hybrid version be available? I've seen many people saying the current range is poor. If it doesn't come out soon, I might have to switch to something else.
I have a 2022 2.0L Premium model. I've noticed some vibrations during driving, and then there's a strange noise from the trunk. It might be an issue with the seal being too thin. Have other owners experienced this?
I've got a 2022 GTS with over 10,000 km on it, and I've noticed an issue. When I turn the steering wheel all the way while moving forward or reversing, there's sometimes a loud noise from the chassis. It sounds like something is stuck or like a brake squeal. Has anyone else experienced this?
