Dear esteemed Levin owners, can the Levin 1.2T's transmission, when used for normal commuting and occasionally driven a bit aggressively, last for 200,000 kilometers?
Is it normal for the steering wheel to shake when driving at 120 km/h on the highway after the car has been driven for 100,000 kilometers?
I last changed the oil in August last year and have driven less than 10,000 kilometers since then. Do I need to change the oil now, and what's a good type to use?
Hey guys, for the 2018 2.0L model used for commuting, is it normal if it costs a bit over 1 RMB per kilometer?
4How often should the transmission fluid be changed? It's been almost two and a half years, and I've driven nearly 40,000 kilometers. The dealership suggests replacing it.
5Is the clutch very heavy? Do I need to replace the clutch kit, or should I replace something else? Or is this normal? It's a 2014 model with over 200,000 kilometers, and I just got it as a used car.
6Hey fellow car owners, is this sound normal? My car is from 2018 and has over 110,000 kilometers on it.
7I have an 18 model Red Label automatic luxury version. Occasionally, at low speeds, I feel like the gear shifts are particularly delayed and the transmission feels a bit rough. Other times, it's very smooth. Does anyone know what's going on? I changed the transmission fluid at 60,000 kilometers, and it's currently at 80,000 kilometers.
8How many kilometers can the clutch slave cylinder of a manual Sunny typically last? Mine seems a bit off, but the gear shifting is all normal.
9Is it reasonable to buy a 2013 car with 130,000 kilometers, manual transmission, single owner, at a fixed price of 8500 from a dealer? Can it be driven for another 2 years?
10I'm particularly curious: I bought a 2017 Macan 2.0, and I've driven it over 70,000 km with good maintenance. Normally, how many more years can it last?
