Is there anyone with a Levante experiencing a ticking noise when idling after warming up the car? The noise disappears when you press the accelerator a bit. What could that sound be?
Comments( 9 )
When the windows are closed and the music is off, I can hear a faint ticking noise while gently pressing the accelerator in park mode. It seems to come from the center console, like a small motor vibrating. When I press the accelerator hard, the sound disappears. I can also hear it occasionally when driving at low speeds or when releasing the accelerator. The noise is noticeable when starting the car cold, and it feels like a metal-on-metal vibration or collision underfoot. Interestingly, after driving for a while, the sound goes away. However, if the car is stopped for a while and then started again, the noise returns initially but disappears after driving for a bit.
I have a 2018 GS7, and the engine vibrates a bit when idling. There's also a slight ticking noise when driving, which started recently. Can anyone help me figure out what might be causing this?
I have a 2016 S5 manual, and recently the engine noise has become quite loud, with a rattling sound. The mechanic said the tensioner bearing is broken. When I'm driving and press the accelerator, there's a ticking sound that gets faster the more I press it, but it stops when I release the pedal. Does anyone know what might be happening...?
4There's a rattling noise like a loose plastic shell when accelerating while driving, but it's not there when revving in neutral. The noise also disappears when you press the accelerator pedal down hard after accelerating.
5When you warm up your car or are idling at a red light, can you hear a "tatata" sound inside the car? Sometimes it's there, sometimes it's not. It's not the engine sound. Even if you press the accelerator a bit, the "tatata" sound frequency stays the same. Not sure what's causing it.
6Is there anyone with a Levante experiencing a ticking noise when idling after warming up the car? The noise disappears when you press the accelerator a bit. What could that sound be?
7I have a 2023 Jietu X90 Zilong Changsheng version. When starting and accelerating, the engine roars loudly. Is it the same for everyone? There's no engine noise when it's idling, but as soon as I press the accelerator to start, the engine sound is quite loud.
8What could be causing the Luxgen M7 engine to make a knocking noise when cold, but not when warmed up?
9What could be the issue if my manual Jetta's transmission makes a rumbling noise, but the sound disappears when I press the clutch?
10Does anyone else experience a ticking noise from the B-pillar while driving? That kind of tick-tock sound.
