Why is there a beeping sound 3 times in a row while driving, even though everything on the dashboard appears normal?
I'm not sure why your tires appear underinflated, especially the front ones, even though all four tires are at 250 kPa.
4Why does the car sometimes not respond when starting, even though the battery and dashboard lights are normal?
5Anyone knows why the 3008 shows the door is open on the dashboard even though it's closed?
6Why does the car beep three times when starting, like the sound when a door isn't closed properly?
7I have a question for everyone. Occasionally, when opening the door of my 2021 Subaru Outback, the hazard lights flash a few times accompanied by a beeping sound, then it disappears. There's no indicator light on the dashboard, and there's no issue while driving. What could be the reason for this? I've been driving it for a few years and it's the first time I've encountered this situation.
8When driving the Kamiq, if a red "P" appears on the dashboard and there's a beeping sound similar to the seatbelt alert, what could be the issue? Can anyone advise? Thanks!!
9While driving the KAMIQ, a red "P" appears on the dashboard, accompanied by a beeping sound similar to the seatbelt warning. What could be the issue? Thank you!
10Help, everyone! Has anyone experienced this? While driving, the dashboard suddenly shows "brake," and the car brakes automatically, even though there's nothing in front.
