حسين عبد القادر
حسين عبد القادر
Feb 7
When reversing and turning the steering wheel, there's a clunking sound coming from the right front wheel. Sometimes it also sounds like the tire is crushing gravel. What could be the issue? There's no noise during normal driving, only when reversing or turning the wheel to a certain angle. Is it due to worn-out control arm bushings or is it an issue with the steering rack?
حسن حمزة
حسن حمزة2024-02-11 23:09
My Legacy has the same issue.
حسين صالح
حسين صالح2024-02-08 00:15
It is likely the Ackermann angle.
I've replaced the control arm ball joints, steering rack, and shock absorbers, but the chassis still makes a thumping sound. What could be causing this?
What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
Hi, what could be causing the steering wheel to make a buzzing sound when turning?
Is it normal for my steering wheel to make a rustling sound when I turn it more than one full circle during a U-turn or while reversing? I just got my Seetus Luxury Edition 20 days ago.
Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
When you hear a clunking sound after turning the steering wheel, what's going on?
Volkswagen Jetta 13 manual fashion 1.6 has a noise when turning the steering wheel. There is no sound when the steering is turned in place, but when driving and turning the steering wheel to the limit, it makes a noise. What could be the reason?
When turning the steering wheel of the MG HS, there's a clicking sound on the left side.
I have a question. For a 2017 Honda City with 90,000 kilometers, when I turn the steering wheel fully to the left while reversing, I hear a clicking sound. But when I turn it to the right, there's no sound, and there's no pulling to one side when driving on the highway. What could be the problem?
What's going on with the knocking sound when slightly turning the steering wheel on the 2021 Jeep Compass?
Subaru Legacy
Subaru LegacyTBDPetrol
