خالد إدريسي
2023-12-29 08:21
What could be the issue if there's a clicking sound from the steering wheel when idling?
خليف حسن
خليف حسن2024-01-19 21:17
Did you turn on the AC? If the AC flap motor is broken, try setting it to blow only upwards or downwards to see if it works.
When reversing and turning the steering wheel, there's a clunking sound coming from the right front wheel. Sometimes it also sounds like the tire is crushing gravel. What could be the issue? There's no noise during normal driving, only when reversing or turning the wheel to a certain angle. Is it due to worn-out control arm bushings or is it an issue with the steering rack?
Hi, what could be causing the steering wheel to make a buzzing sound when turning?
Is there a clicking sound coming from the engine?
When I turn the steering wheel of my MG ZS, I hear a clicking noise and feel vibrations under my feet. What could be the cause of this?
When you hear a clunking sound after turning the steering wheel, what's going on?
Volkswagen Jetta 13 manual fashion 1.6 has a noise when turning the steering wheel. There is no sound when the steering is turned in place, but when driving and turning the steering wheel to the limit, it makes a noise. What could be the reason?
When turning the steering wheel of the MG HS, there's a clicking sound on the left side.
When shifting from D to neutral, there is a clicking sound. What could be the problem?
I have a question. For a 2017 Honda City with 90,000 kilometers, when I turn the steering wheel fully to the left while reversing, I hear a clicking sound. But when I turn it to the right, there's no sound, and there's no pulling to one side when driving on the highway. What could be the problem?
Subaru Subaru Legacy
Subaru LegacyAED 82,000 ~ 109,000Gasoline
