My Legacy has driven over 30,000 kilometers, and after passing through some bumpy roads, there's a creaking sound in the cabin, like an old car. How can I fix this? Any advice, experts?
Hey everyone, I recently noticed a rustling noise near the B-pillar on the passenger side when driving over bumpy roads. I've had the car for a year, but this just started happening. It doesn't make noise on regular bumpy roads, only when the car sways side to side. I've tried fastening the seatbelt and applying grease to the buckle, but the noise persists. Has anyone else experienced this? Any suggestions on how to fix it?
I bought a second-hand 2014 Kia Sportage, and the exhaust smells really bad. I hadn't driven it on the highway before, but a few days ago I did, and the engine warning light came on. The check indicated an issue with the oxygen sensor. After replacing it, the error code was cleared, but a few days later it came on again. It seems fine when not driving on the highway, but as soon as I do, the light comes on and stays on. Can any experts advise on how to fix this issue?
4When driving over bumpy roads, there's a suspected noise coming from the chassis around the rear axle area (a creaking sound). I want to ask if anyone else is experiencing this too?
522,000 kilometers. When I went back home for the New Year on bumpy roads, I noticed a creaking sound when turning. Has anyone else experienced this issue? I have no idea where the problem might be. When I press down on the rear trunk, it doesn't make the sound, only when driving and turning. Sigh.
6At extremely low speeds, there's a crisp sound from the relay contact when kinetic energy recovery engages. In creep mode, it occurs just when the brake is applied during low-speed crawling. Without creep mode, it happens when you release the accelerator at low speeds. It's just one crisp sound, coming from near or in front of the pedal. The sound is very faint, and can't be heard with the windows open, music playing, or on a bumpy road. This is with the first launch of the dual-motor. Has anyone else encountered this issue, and can it be fixed?
7Is there any car owner experiencing a noise from the right rear wheel? When the temperature is low, there's a squeaking sound when going over speed bumps. There's no abnormality during normal driving, and it doesn't make noise on bumpy roads. The shock absorber isn't leaking either. The car is only three years old, so it shouldn't be the stabilizer bar bushing issue, plus the sound doesn't seem like it's from the stabilizer bar bushing.
8Noise issue, seeking advice from experts. I have a 2020 1.6 manual ASX. When driving on highways or national roads, once I go over 100 km/h, there's a knocking sound from the back after a bump, like a board isn't fixed properly. Yesterday, it was really annoying while on the national road. Even after stopping the car and restarting it, the knocking sound was still there. When I got home and tested it again, it was gone. This has been happening for a while, and I've checked multiple times but couldn't find the cause. Considering yesterday's situation, I suspect it might be an exhaust pipe issue. Has any fellow car owner experienced a similar problem?
9I need some guidance from the experts. I'm new to cars and currently, my family doesn't own one. My husband works nearby, but I commute 40 kilometers to the suburbs for work every day. We live in an old neighborhood without home charging facilities, and I'm thinking of buying a new energy vehicle. I've had my license for six years but haven't driven much. I liked the appearance of the Zeekr X but heard the rear space is small. Personally, I like Zeekr and Ora, and I'm also considering Deepal. I'm really confused and don't know which car to buy. Any advice from the experts would be appreciated.
10Does your car make a creaking noise on bumpy roads? I took mine to the service center, but they couldn't find anything. Does anyone else have this issue?
