فهد سعد
2023-07-19 16:39
Why can't the front left and rear left doors of my Mazda 5 be raised or lowered?
Is the heads-up display text in the RDX slightly higher on the left and lower on the right?
Hello fellow car enthusiasts, I own a Patrol Y62. A few days ago, while driving, the lower ball joint on the left rear wheel suddenly broke. Do you know what might have caused this?
My 2009 Touran's right rear fog light is broken, but the dashboard indicates a left rear fog light failure.
How many control arms are there on the right rear suspension of the 2018 Hongqi H7 if the control arm and lower arm are bent?
Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
I accidentally hit the curb with my left rear wheel and the tire got damaged. During the four-wheel alignment, they said it couldn't be fully adjusted. If the tire is damaged, does it really require changing the shock absorber? Is it really that serious?
Today, while washing my car, I noticed that all the left side windows have markings, but the three right rear windows don't. What's going on here? Did I accidentally buy a damaged car? I own a 2021 Subaru Outback flagship model.
Is there a problem if the tire pressures are different? Front left 240, rear left 250, front right 240, and rear right 233. Is it okay to drive?
Subaru Subaru Legacy
Subaru LegacyAED 82,000 ~ 109,000Gasoline
