عبدالرحمن صارم
2024-02-27 16:24
How often should differential oil be changed?
سعود قابوس2024-03-22 16:07
When changing the transmission oil, also replace the filter.
محمد بدر2024-03-09 11:27
I exchanged it for 40,000.
هكيل أحمد2024-03-05 21:22
Some shops say 45,000, some say 60,000.
Does anyone know how often the transmission oil should be changed for a gasoline Korando?
How often should the rear differential oil for the RDX AWD be changed, and what brand is used? 😊
How often should the gear oil be changed for the Rapid?
4How often should differential oil be changed?
5How often should the transmission fluid be changed?
6How often should transmission fluid be changed?
7How often should the transmission oil be changed?
8What type of engine oil do people generally use for a newly purchased second-hand 2008 2.0? How often should the transmission oil be changed? Thanks!
9How much differential oil needs to be changed?
10How often should brake fluid be changed?
