How can I set the car lights to turn off automatically when the door is closed? It's always draining the battery and it's super annoying...
Will the driving lights turn off automatically after locking the car if they are not switched off?
For the 2012 Honda City, the doors can only be opened after turning off the engine. How can you set it to open the doors without turning off the engine? Also, when the car starts and you press the brake, the doors automatically lock.
4Why is the engine light on my 2017 Haval H2 Red Label Automatic 1.5T Luxury always on and not turning off?
5After ignition, the hazard lights automatically turn on and can't be turned off, but they disappear after turning off the engine. The hazard lights can be used normally otherwise. What's going on?
6Does anyone know if the light inside the trunk of a Haval H2 stays on continuously when opened? If I keep it open for half a day, will it drain the battery? Some car models have a feature where the trunk light turns off automatically to prevent battery drain.
7When I start my Seitus 23 Luxury, the radio automatically turns on. How can I turn it off? It's so annoying that I feel like removing the radio altogether.
8The small light on the upper left corner of the driver's door stays on even after turning off the engine and locking the car. Does anyone know what this light is and how to turn it off? 🌹
9I have a 2016 automatic Santana, and the ABS light occasionally turns on and off. When I took it for a check-up, they said there was no problem, and it drives fine. It's just annoying to see the light on. Any idea what's going on?
10Hey guys, how do you avoid the small battery draining and getting error codes when tinting? Should I keep the car running or turned off? I noticed that the car doors are open during the tinting process.
