Hey folks, my manual Legacy feels powerless under 2000 RPM. Even when I step on the gas pedal hard, there's no response. What's going on?
Hey folks! Anyone else experiencing this with their Yizhi? What's the issue with the idle speed fluctuating when starting a cold car? Sometimes it hits 2000 RPM right after starting.
Is it normal for a 2015 model to have a smooth start without accelerating, but require around 2000 RPM to start with acceleration, and then feel a noticeable jolt and tire slip?
4When stuck in traffic, frequently braking and accelerating might lead to no response from the gas pedal. You'll need to idle forward a bit before the accelerator responds, or you can restart the engine to temporarily fix the issue.
5The 2017 Land Cruiser with an automatic transmission struggles to accelerate when flooring the gas pedal, with the RPM not going above 2300, causing slow acceleration. However, when using cruise control, the acceleration is faster, and the RPM can increase. What might be the reason for this?
6I feel like the brake pedal on my Jeep Compass is both hard and high. Does anyone else notice this on their car?
7Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
8The 10-year-old 1.5 manual car experiences severe vibration in the gas pedal at 3000 RPM in any gear, making it difficult to press. Does anyone have a solution for this issue?
9Hey car enthusiasts, can anyone help me out? My 2015 manual Sunny only revs up to 2000 RPM when I floor the gas pedal, and the acceleration feels weak. What could be the issue?
10Is your 2015 Jetta also like this, where the RPM only reaches around 3800 when you floor the gas pedal in neutral and doesn't hit 4000?
