عبدالرحمن صارم
2023-05-07 17:30
Did anyone with a 2018 Subaru Legacy with Eyesight not tint the windshield because the manufacturer advised against it, saying it might affect the Eyesight system? I'm considering tinting now and want to know if anyone has done it and if it affected the Eyesight system.
Comments( 6 )
أحمد محمد
أحمد محمد2023-08-17 15:03
Don't worry about the film, it doesn't affect it at all. I already applied it. [Thumbs up]
خالد عبد القادر
خالد عبد القادر2023-07-16 23:52
I've applied a high-transparency film to my 2022 Forester, and it doesn't affect visibility.
فهد بكران
فهد بكران2023-05-15 01:11
As long as you use a film with high light transmittance, it won't have any impact.
خالد رمضان
خالد رمضان2023-05-14 20:11
For the front windshield, aim for high transparency. As for the sides and rear, it depends on personal preference. Heat insulation is important, but safety is even more crucial.
عمر هشام
عمر هشام2023-05-12 17:57
No worries, I got the 2020 model.
عبدالله عباس
عبدالله عباس2023-05-09 12:31
No stickers. After all, cars are consumer goods, no need to be too particular.
The dealership mentioned today that applying a film on the front windshield could affect the ES system. Is that true? What would be the impact if the front windshield isn't tinted?
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
Does the 2018 Subaru Legacy EyeSight Honor edition have a tire pressure monitoring system?
Has anyone managed to hack the infotainment system of the 2019 Trumpchi GA6 to download third-party apps, or how to upgrade the built-in AutoNavi map? The current version is really hard to use, and the manufacturer probably won't push any updates.
Is there anyone selling a Subaru Legacy in the Pearl River Delta region?
Hey folks, are your car lights bright enough? I'm thinking about changing mine because they don't seem bright, but it looks like I have to remove the entire headlight to do it. Has anyone done this before? Any advice?
My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
Has anyone experienced this? I went to the 4S shop for the second maintenance of my GS8 fuel version, and they required adding a fuel system cleaner. They said it's mandatory according to manufacturer regulations.
Does anyone know the original brand of loudspeaker for the Tiida? I have the 2024 model, and I'm thinking about upgrading the audio system. Has anyone done it?
Subaru Subaru Legacy
Subaru LegacyAED 82,000 ~ 109,000Gasoline
