حسين شمس
2024-12-05 10:45
What could be causing a rattling noise near the windshield and center console? It sounds like a loose screw humming.
حسن بشار
حسن بشار2024-12-05 12:16
My interior rearview mirror is making a noise.
حسن جمال الدين
حسن جمال الدين2024-12-05 12:11
Sometimes it's just a matter of finding and removing some of the tougher leaves.
SAIC Maxus 2020 T60 2.0T diesel 4WD, 1.5 years old. There's a vibration noise coming from the center console when the RPM is between 1800 to 2000 in low gear. What could be the cause?
Does your MG One's center console have any unusual noises?
Anyone experiencing rear axle noise? The rear wheels aren't splayed, and there's no looseness, but on uneven roads, there’s always a rattling sound from beneath the rear seat. Does anyone know what the issue might be?
The air conditioning in my 2019 model Yueshang only blows air towards the front windshield, while there's no air coming from the center console or side vents. Does anyone know what might be causing this issue, and is it complicated to repair?
To replace the gear shift boot on a manual 2018 MG ZS, follow these general steps: 1. **Remove the Gear Knob**: Unscrew the gear knob by turning it counterclockwise. Some models may have a clip or screw that needs to be removed first. 2. **Detach the Center Console**: Depending on the design, you may need to remove screws or clips holding the center console in place. Carefully lift the console to access the boot. 3. **Remove the Old Boot**: The boot is usually attached to the console with clips or staples. Gently detach it without damaging the console. 4. **Install the New Boot**: Secure the new boot onto the console by attaching it with clips or screws, ensuring it fits snugly. 5. **Reattach the Center Console**: Place the console back and secure it with screws or clips. 6. **Reattach the Gear Knob**: Screw the gear knob back on by turning it clockwise. Make sure everything is securely fastened and test the gear shift to ensure smooth operation.
Does anyone else hear a rattling sound during the start-up acceleration of the 2023 Mini S? What could be the cause?
The sound of rustling near the throttle belt on a 10-year-old Alto could be due to several reasons. It might be caused by a worn-out or loose belt, debris stuck in the belt area, or possibly an issue with the belt tensioner. It would be best to have it inspected by a professional to determine the exact cause.
A car from March 2024, there's a rattling sound on concrete roads. The trunk makes noise, the center console island makes noise, and the seats make noise. It feels like the whole car is rattling.
Is there anyone who has experienced rattling noises from the center console screen and the driver's side door when driving on uneven roads in the 2019 Taurus? It's driving me crazy!
Do you have any abnormal noises coming from the center console of your car? When in Drive (D) and holding the brake, there's a "dang dang dang" sound from the driver's center console. There aren't any issues in other gears.
