Is it normal for the Langyi 300T to have a delay of 3 seconds at 2000 RPM in third gear when the engine is cold?
Is it normal for the 2008 imported Mazda 3 to have a cold start RPM of 1600, with a particularly loud noise that decreases after about a minute?
I want to ask about my 2019 Changan Yuexiang automatic. When I start the car cold and shift gears, it takes about 2000 RPM to change gears, like the clutch is slipping. Once the engine warms up, the shifting is normal. Do other car owners experience the same issue?
Is it normal for the Yizhi to have an RPM of 2500 during a cold start in the morning?
4Is it normal for the Sharan to shift gears at 3000 RPM when climbing?
5It's normal for your NV200 to have a high idle speed of 2000 RPM when you start it cold, and then drop to 800 RPM after about a minute. This process helps the engine warm up. However, if it feels inconvenient, you might want to consult a mechanic to see if any adjustments can be made.
6Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
7Hello everyone, could someone help me with this issue? When in Park and idling, if I rev the engine above 1600 RPM and then release the throttle, the RPM stays around 1600 for about ten seconds before it drops. This doesn't happen if I don't exceed 1600 RPM. Between 1600 and 2000 RPM, there's a noticeable jolt. Additionally, when shifting gears and slowly accelerating, there's a rattling noise between 1600 and 2000 RPM, but it disappears after 2000 RPM. Does anyone have any insights on this? I would really appreciate it. The car model is a 2016 30T two-wheel drive. Thank you very much!
82017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
9Is it normal for a 2015 Nissan Sunny manual transmission, with 80,000 kilometers, to have the RPM at 2000 when going over 70 mph in fifth gear?
10Does anyone else experience their engine roaring at 2000 RPM?
