أحمد حميد
Dec 5
I'd like to ask fellow car enthusiasts: Is it normal for the left headlight on a Lavida, after 5 million units, to shine closer than the right one? Is it adjusted this way from the factory?
If you feel dizzy when looking at the left side mirror because it seems magnified, especially after switching your gaze from the right, it might be due to the mirror's curvature or your seating position. Consider adjusting either the mirror or your seat to find a more comfortable view.
Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
4I bought the 2019 Bestune T99 in September 2020. Since it was my first car purchase, I lacked experience and fell into many traps. Besides having many minor issues, I later discovered several parts were damaged. The tires were previously used, which immediately made me suspect that this car was probably a test drive vehicle. And I was right. A few days ago, I went to replace the turn signal lights and found that the wiring inside had been reconnected, and the connections were poorly done. Moreover, the production dates of the left and right turn signals were almost a year apart. (Cars from the factory have uniform dates.) After all these years, it's impossible to explain this to the dealership now! I hope everyone pays attention to details when buying a car to avoid being deceived.
5I've been driving a Touran for 7 years, and it's time for a change. I'm looking for recommendations based on my needs. Here's what I'm looking for: I commute 25km one way to work, and there's no fixed parking spot in my community. The city is crowded, which tests my driving skills, so the car can't be too big. I'd like a space for a nap at noon, so electric or plug-in hybrids are preferred. We are a family of three, and we often take the kid out on weekends, so the car's stability and smooth driving are important as my family gets car sick easily. I often take care of the kid alone, and since the kid is not very strong, an electric sliding door would be great. My kid likes camping in the car, so it needs to have ample space. Occasionally, I need to move things between houses, so flexible space is a plus. Since my wife doesn't drive, we can only have one car. Right now, it seems like the GAC E8 is the only option 🤣
6This car should be better than the 5 Series except for the space, right?
7For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
8Can the new Jetta's headlight cover, which is higher than the grille, be adjusted to be level? Any car enthusiasts who know about this, please give some guidance.
9After 8 years with my old petrol car, it started burning oil, and I noticed a lot of people around me were switching to electric vehicles. That got me thinking. I was originally planning to get the top-spec Tank 300 (Menglong), and during the National Day holiday I went for a test drive — it met my expectations.On the way back, I stopped by a Jetour dealership and saw the T2. My daughter instantly fell in love with the exterior and interior — it completely overshadowed the Menglong in her eyes. Looks clearly played a big role, and after a test drive, it felt good enough. Since I don’t really need 4WD for daily driving, I booked it right away. Looking back now, I do wish I had waited for the 4WD version — a bit more power would’ve been nice.For this type of vehicle, electric power saves a lot. For daily use, my cost is just around 0.10 AED/km (charging at home on off-peak rates of 3.3 AED/kWh). My daily round-trip to work is under 20 km, so I only charge every four days, when the battery hits around 20%.For long-distance trips, I don’t bother with charging — it’s too much hassle. I just set the car to preserve 60% battery and drive on petrol. Even if fuel consumption is slightly higher, it’s fine since I only do a few road trips per year.The car is heavy and feels solid on the road. Acceleration is decent, but the 4WD version definitely would’ve offered better power and confidence. I’ve had the car for over half a year now. So far, the only issue has been a slight noise from the steering system — which was fixed. Other than that, no major problems. Buying a car always involves a bit of luck anyway.The biggest downside is the driver assistance system — it lags behind the competition. The infotainment system has improved a bit with the latest 4.11 update, but it still has room for improvement.Overall, I’m quite satisfied. Compared to many newer EV startups, Chery is an established brand. The lifetime warranty adds a lot of peace of mind, especially on the powertrain and electric components.
10I was looking for a good sedan, and I went through the usual headache of choices like anyone else. I looked at the Sentra and the Civic—each had something I liked, but also something that made me hesitant. The Sentra felt a bit too quiet for me—I’m still young—and while the Civic was tempting, I just couldn't fully buy into it. I randomly walked into a Toyota showroom, and right there in front of me was the Corolla. I took it for a test drive, and honestly, the sales team was incredibly polite and respectful—unlike the staff I’d dealt with at other dealerships. In the end, I was convinced and bought the hybrid Corolla. After a year of use, the car has been comfortable and smooth to drive, with no major issues. But it’s not without its annoyances—like the sluggish, outdated screen and the old-school head unit, so I replaced them. Even the seats and the center armrest would get dirty easily, so I had them covered in leather. The headlights were halogen, so I swapped them for LEDs. The horn also sounded weak, so I changed that too. In terms of performance, it's decent—not a rocket, but more than enough for daily commutes. At speeds over 120 km/h, the car felt a bit floaty, so I upgraded the wheels and tires from 16" to 17", which really improved its stability. The most impressive thing, hands down, has been the fuel consumption—it once dropped to 3.9L/100km! But after I accidentally reset the system, it now reads 5.3 and I can't figure out how to get it back. Space-wise, it's fine—comfortable up front, and okay for two people in the back, but three will feel cramped. The one thing that really bugs me is the A/C, especially for rear passengers. There aren’t effective rear vents, and airflow is a bit weak during summer. I enjoy tweaking my car, so I’ve done a lot of modifications—brakes, tires, wheels, lights, sound system, and a few small accessories. Overall, though, I’m satisfied. My advice for anyone planning to buy one: don't go for it just because everyone else is. Buy it because you’re personally convinced. Compare prices and features carefully. At the end of the day, the Corolla is a solid, respectable car. It won’t let you down, but it’s not perfect—there are things that need a bit of work, depending on your preferences and how willing you are to spend a little more after buying it.
