نايف آسيا
2024-09-16 11:58
Why was the control panel completely changed? Will it be added back later?
صارم محمد
صارم محمد2024-10-21 01:41
It's really frustrating when they follow others in removing physical buttons.
سلمان طلحة
سلمان طلحة2024-10-05 23:50
Model Range
It is said that Acura is exiting the Chinese market. Will there be imported cars coming back later?
Why did the reverse gear suddenly stop working, but it was fine an hour later, on a Trailblazer?
What's that vertical panel at the back of the middle seat for?
Why does the Taycan revert to normal mode after changing the driving mode settings and getting back in the car?
The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
The difference between the "Cancel Cruise" and "Turn Off Cruise" buttons on the steering wheel of a Patrol is as follows: - **Cancel Cruise**: This button temporarily deactivates the cruise control while keeping the set speed in memory. You can resume the cruise control to the previously set speed later without having to set it again. - **Turn Off Cruise**: This button completely deactivates the cruise control system and clears the set speed from memory. To use cruise control again, you would need to set the speed anew.
Has anyone changed their transmission oil? How many liters did you use, and did you do a gravity change or a complete flush?
Is there anyone who has added rear air vents for a small car? It's really hot in the back seat.
Does the 2021 stock 5008 need a complete fluid change and battery replacement?
Landrover Land Rover Range Rover
Land Rover Range RoverAED 379,000 ~ 860,754Gasoline
