محمد شخبوط
2024-11-30 13:22
What should I do with the previous 21-inch wheels and tires if I upgrade to larger wheels for my Shengshi?
أحمد قاسم
أحمد قاسم2024-12-02 13:34
Eaten.
2
Can the stock 21-inch wheels of the Hongqi EHs9 be upgraded to 22-inch wheels?
You can consider upgrading the wheels on your Subaru Liberty Wagon to a larger size to prevent scraping against the chassis and front end. Typically, people upgrade to 17 or 18-inch wheels for better clearance and aesthetics. However, make sure to check for compatibility with your vehicle's suspension and wheel well space, and consult with a professional to ensure safety and performance.
Will the tire wall be too thin and prone to bulging if I choose 22-inch wheels?
Are the 21-inch five-spoke wheels only available for the flagship model?
What should I do if there's rust inside the wheel?
If we're talking about the SP model, is it necessary to choose 21-inch wheels? Would the 30 aspect ratio rear tires be prone to bulging easily?
Hi everyone, I want to ask about the 2024 Cayenne. When I bought the car, there were no 21-inch wheels available, so I got the original 20-inch ones. Now I'm planning to change them. Should I go for the 20-inch bird's nest wheels or directly switch to 21-inch tires and wheels? I'm not very familiar with this. I've heard that 21-inch wheels might affect comfort and increase noise. A friend who repairs cars also says I don't need 21-inch wheels, but I'm worried I might regret sticking with 20-inch. Any advice?
Is it normal that after switching from the original 19-inch wheels to the 21-inch ones that came with my 2024 Panamera, the ride feels less smooth and acceleration seems slower?
How do I adjust the gap between my car doors if it has become larger?
Consulting everyone, if I change my manual 30 to high-end 18-inch wheels, do I need to modify the brake discs and calipers?
Land Rover Land Rover Range Rover
Land Rover Range RoverAED 379,000 ~ 860,754Gasoline
