عبد العزيز هادي
Nov 27
I just got the 2025 5-seater Shengshi. Is it necessary to upgrade to the 800-watt loudspeaker? The factory 400-watt ones really don’t perform well...
Choosing your first performance car is an exciting decision! Here's a brief rundown of your options: 1. **2003 Subaru Impreza STI**: Known for its rally heritage, it's great for all-weather performance and has a strong AWD system. However, it might be older in terms of technology and features. 2. **2013 Toyota 86**: Offers a balanced rear-wheel-drive experience, known for its handling and driving fun. It's a bit less powerful but very engaging to drive. 3. **2014 Ford Fiesta ST**: A fun, nimble, and affordable hot hatch. It's smaller and great for city driving, with a lively turbocharged engine. 4. **2014 Volkswagen Golf GTI**: A well-rounded hatchback that combines performance with practicality. It's comfortable for daily driving and has a strong community and aftermarket support. 5. **2004 Mitsubishi EVO 8**: Another rally-inspired choice, with strong performance and an AWD system similar to the STI. It may require more maintenance due to its age. Your choice should depend on what you value most—whether it's all-wheel-drive performance, rear-wheel-drive dynamics, or a mix of practicality and fun. Also, consider maintenance costs, reliability, and availability of parts for these older models.
Maintenance guide for the 2007 Opel Astra: 1. **Regular Oil Changes**: Ensure you change the engine oil and oil filter every 5,000 to 7,500 miles to keep the engine running smoothly. 2. **Brake System Check**: Inspect brake pads and discs regularly, approximately every 10,000 miles, and replace them as needed to ensure safety. 3. **Tire Maintenance**: Check tire pressure monthly and rotate tires every 6,000 to 8,000 miles to ensure even wear and prolong tire life. 4. **Air Filter Replacement**: Replace the air filter every 15,000 to 30,000 miles to maintain optimal engine performance. 5. **Coolant Level**: Check and top off the coolant level regularly to prevent the engine from overheating. 6. **Battery Check**: Ensure the battery terminals are clean and the battery is functioning properly, especially before winter. 7. **Transmission Fluid**: Inspect and, if necessary, replace the transmission fluid every 30,000 to 60,000 miles to ensure smooth gear shifts. 8. **Spark Plugs**: Replace spark plugs every 30,000 miles to maintain fuel efficiency and engine performance. 9. **Suspension and Steering**: Regularly inspect the suspension and steering components to ensure a comfortable and safe ride. By adhering to this maintenance schedule, you can help ensure your 2007 Opel Astra continues to perform reliably.
4You can consider upgrading the wheels on your Subaru Liberty Wagon to a larger size to prevent scraping against the chassis and front end. Typically, people upgrade to 17 or 18-inch wheels for better clearance and aesthetics. However, make sure to check for compatibility with your vehicle's suspension and wheel well space, and consult with a professional to ensure safety and performance.
5When buying a 2008 Yaris, here are some areas you should check: 1. **Exterior and Interior Condition**: Inspect for any signs of rust, dents, or scratches on the exterior. Check the interior for wear and tear, especially the seats, dashboard, and electronics. 2. **Engine and Transmission**: Listen for any unusual noises from the engine and ensure that the transmission shifts smoothly. Look for any leaks or corrosion. 3. **Brakes and Tires**: Check the condition of the brakes and ensure the tires have sufficient tread and are evenly worn. 4. **Suspension and Steering**: Test the suspension and steering for any unusual noises or stiffness. 5. **Electrical Systems**: Make sure all lights, indicators, and other electrical components are functioning properly. 6. **Service History**: Review the vehicle’s service history to ensure it has been well-maintained. After purchasing the car, here are some maintenance tips: 1. **Oil Change**: Start with an oil and oil filter change if it’s not recently done. 2. **Replace Air Filters**: Check and replace both the engine and cabin air filters if necessary. 3. **Check Fluids**: Ensure that all fluids (coolant, brake fluid, transmission fluid, etc.) are topped up and in good condition. 4. **Inspect Belts and Hoses**: Look for any signs of wear and replace if needed. 5. **Battery Check**: Ensure the battery is in good condition and clean the terminals if there is any corrosion. 6. **Spark Plugs**: Consider replacing the spark plugs if they haven’t been changed recently. 7. **Tire Maintenance**: Rotate the tires and check wheel alignment. By taking these steps, you’ll help ensure that your Yaris remains reliable and performs well.
6Model X owners, what cars are you upgrading to or purchasing? I currently have a 2017 Model X 100D 5-seater, which is over 4 years old. Recently, when going out with my daughter, I often have to let her mom drive so I can sit in the back with her. The rear seats are really uncomfortable, and my daughter tends to get carsick easily. I'm thinking about getting another car, considering 6-7 seat SUVs or MPVs, but haven't decided yet. What have you all bought?
7Choosing between the G80 and the XFL depends on your personal preferences and needs. Here are some things to consider: 1. **Brand and Model**: - G80 generally refers to the Genesis G80, a luxury sedan known for its comfort and advanced technology. - XFL typically refers to the Jaguar XFL, which is the long-wheelbase version of the Jaguar XF, offering more rear-seat space and luxury features. 2. **Performance**: - Consider the engine options and horsepower each model offers. The G80 might offer a more powerful engine, while the XFL might focus on a balanced ride. 3. **Features**: - Look at the features each car offers, like the infotainment system, loudspeakers, safety features, and interior quality. The G80 is known for its tech-savvy features, while the XFL may emphasize luxury and style. 4. **Fuel Economy**: - Check the fuel economy for both. If fuel efficiency is a priority, this might influence your decision. 5. **Comfort and Space**: - If rear-seat space is important, the XFL might have the edge due to its extended wheelbase. 6. **Budget**: - Consider the price and what fits better within your budget, including maintenance costs. Ultimately, test driving both and considering these factors could help make your decision easier.
8I'm considering a 2025 model, either 7-seater or 5-seater, and I'm undecided. The 5-seater is spacious and has that luxury car vibe, but the 7-seater seems more practical for me personally. Has anyone who has bought a 7-seater or 5-seater got any advice to share?
9I had the chance to try out the new Toyota Corolla, the 1.2T Elite version. Honestly, there aren’t many changes in the design compared to the previous generation, but I thought I’d share my thoughts anyway. The engine performance isn’t particularly strong — 116 horsepower on a car this size is just acceptable. But when you push it and let the RPMs climb, it actually feels better than expected. It’s not slow, and it feels lighter than I thought it would. The CVT gearbox is smooth and decent overall, although at low speeds there are some light vibrations and a bit of drag when you lift off the throttle. When you demand sudden acceleration, it takes a little time to reach the higher revs, but it’s not annoying. The suspension handles big bumps well, but you can feel smaller imperfections in the road, especially at lower speeds. On curves and sharp turns, the car holds itself pretty well and stays composed — that was a nice surprise. The steering is great. It’s light at low speeds and firms up nicely as you go faster. The response is smooth and precise, and the brakes are easy to get used to and feel very natural — no issues there. Noise insulation is average. Wind noise is handled well, and the engine isn’t too loud, even at high RPMs — that’s actually better than the hybrid version. But road noise does come through at higher speeds, and ambient noise isolation is just okay. Inside, the design hasn’t changed much — it still feels quite basic. The materials aren’t great; most of the interior is hard plastic. The screen and instrument panel haven’t been upgraded like in the 1.5 or hybrid versions. The infotainment system is slow and outdated — not what you'd expect in a 2024 model. Front seating is fine — you can adjust the driver’s seat to a comfortable low position and the steering wheel aligns well with it. The back seats, however, aren’t great. The space is average, the seatback is a bit upright, and the cushion isn’t very long. The trunk, on the other hand, is decent and handles luggage well. In terms of safety features, you do get useful tools like radar and driving assist, but there’s no rear parking sensor — which is strange. Overall, the car isn’t lacking in features, but the priorities feel a bit off. In the end, this car doesn’t really surprise you — and that might actually be a good thing for people who prefer something reliable and familiar. It’s not futuristic, but if you’re after dependability and ease of use, it could still be a smart choice — especially with how crowded the market is becoming with hybrids and EVs. Ultimately, it depends on your needs and your budget at the time of buying.
10Ride Comfort: The car feels very stable at high speeds, which gives you a real sense of safety — especially thanks to the solid chassis. However, the seats are a bit firm, and on long trips, they can start to get uncomfortable. Fuel Range: On a full tank, I’ve managed around 650 km on the highway. In summer, or when the car is fully loaded with the A/C running, that drops to about 500 km. In the city, I usually get around 400 km per tank. With current fuel prices (I always fill up with 95), it basically costs me around AED 1 per kilometer. Performance: This is the part I really want to talk about — and complain a bit. With ECO mode turned off, the initial power off the line is decent, but that’s about it. Once you get moving, the car starts to feel like it’s struggling — like a small engine pulling a heavy body. If you don’t mind the loud engine noise, you might get a bit of excitement, but realistically, you’re running close to 4000 RPM for that. Overtaking at 120 km/h is tough; the acceleration just doesn’t keep up, and it feels risky. That said, I have to give credit to the car’s off-road capabilities — it handles rough or muddy roads surprisingly well and won’t leave you stuck.
