Hey guys, I want to ask if it's necessary to choose digital headlights for the extended version of the Genesis I'm buying. Are these brighter than the original headlights?
I want to ask about a detail: Is it true that the exhaust on the original MC kit is centered, while the ones that are not original MC are dual on both sides? [Looking] (Maserati GTS)
Hey guys, can the low-end version be fitted with daytime running lights? I want to ask, is there a switch at the left leg position?
I want to ask why the 3.0 six-cylinder version of the GV80 is not introduced in China.
4Should I replace the brake pads with better ones or go for the original ones? What brands do you guys usually choose?
5Can I go to the dealership to ask for a lifetime warranty for the Genesis GV70? I'm worried about the cost of parts in the future, as the original 5-year warranty doesn't seem enough.
6Is it still necessary to choose the original sport exhaust if I plan to modify the exhaust later?
7Do you guys often scrape the chassis when driving? Is it necessary to choose a front axle lift?
8Are you guys renewing the extended warranty? After using up the extended warranty you got when you bought the car, would you choose to continue buying it? Or would you just go to an external shop for maintenance?
9Hey guys, I want to ask if it's necessary to choose digital headlights for the extended version of the Genesis I'm buying. Are these brighter than the original headlights?
10I want to ask if any of you have optional or standard matrix headlights. Is it more practical to upgrade to laser headlights or stick with matrix headlights? I often drive on the highway, and my car originally has low-end LED headlights. I'm considering upgrading, but I'm not sure which option is better.
