عبدالرحمن توفيق
2024-01-25 21:43
Why can't the cruise control on the LC300 be activated? It shows OFF and won't turn on no matter what I do.
How do I turn off the 360 panoramic image that pops up on the central control when turning?
How do I use the cruise control on the 2019 Yuxiang?
To activate the cruise control on the MX-5 NC, first make sure you're driving at your desired speed. Then, locate the cruise control button on your steering wheel or stalk and press it to turn on the system. Once activated, you should see a cruise control indicator light on your dashboard. Adjust the speed using the "Set" or "Resume" buttons as needed.
The central control screen won't turn off. When I press the switch, the screen goes black for a moment and then turns back on. Even a long press doesn't work. What should I do?
How do you activate cruise control on a 2017 Smart? I've been trying for a long time but still can't figure it out.
The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
The difference between the "Cancel Cruise" and "Turn Off Cruise" buttons on the steering wheel of a Patrol is as follows: - **Cancel Cruise**: This button temporarily deactivates the cruise control while keeping the set speed in memory. You can resume the cruise control to the previously set speed later without having to set it again. - **Turn Off Cruise**: This button completely deactivates the cruise control system and clears the set speed from memory. To use cruise control again, you would need to set the speed anew.
The issue with the cruise control not holding could be due to several reasons. While the indicator light on the dashboard shows that the cruise control is activated, it might not maintain the set speed.
How do I turn off this central control screen? Looking for expert advice. 😭
Toyota Toyota Land Cruiser
Toyota Land CruiserAED 215,900 ~ 412,900Diesel & Gasoline & Petrol
