حسين ضربة بكوع إير
2023-10-10 03:07
عمر حرب
عمر حرب2024-04-23 18:49
The accelerator pedal is stuck. 😅
Peugeot 206, 1.6L, automatic/manual transmission, 2006 model. The acceleration is very slow, and when you give it more gas, the RPM goes up, but the speed doesn't catch up. What's going on? Can any experts help explain this? Thanks!
Hey folks, my manual Legacy feels powerless under 2000 RPM. Even when I step on the gas pedal hard, there's no response. What's going on?
When driving, if the car suddenly doesn't respond when you press the accelerator, and even flooring it doesn't increase the RPM, but releasing and pressing it again solves the issue, this could be a problem. When starting on a steep slope, if the car feels powerless and sometimes can't climb, requiring several attempts to increase RPM, there might be an issue to address.
I recently got a 2013 model 2014 Scirocco GTS. Why does the car start shaking and not move when I floor the gas pedal to start?
My Mitsubishi ASX struggles to go beyond 140 km/h on the highway, even with the pedal almost to the floor. The RPM is between 2600-2800. Usually, when driving, the accelerator feels a bit sluggish. Does anyone know what could be the reason?
Hey car enthusiasts, can anyone help me out? My 2015 manual Sunny only revs up to 2000 RPM when I floor the gas pedal, and the acceleration feels weak. What could be the issue?
Is your 2015 Jetta also like this, where the RPM only reaches around 3800 when you floor the gas pedal in neutral and doesn't hit 4000?
Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
Why isn't it turbocharged? With the WRX engine, acceleration would be faster. This acceleration is too slow.
Toyota Toyota Land Cruiser
Toyota Land CruiserAED 215,900 ~ 412,900Diesel & Gasoline & Petrol
