avatar-image
سعود أكبر
Mar 12
Hey guys, my Land Cruiser tends to pull the steering wheel when driving on bumpy roads, and it doesn't feel very stable. I've already done a wheel alignment, and the mechanic said there's nothing wrong. Is the steering wheel pulling a normal phenomenon?
علي خديجة
علي خديجة2024-04-28 23:04
It's normal, gotta hold on tight.
حسين بندر
حسين بندر2024-04-25 11:37
Mechanical assistance, it's normal, just need to feedback road feel.
عمر حرب
عمر حرب2024-04-23 19:01
That's normal, everyone will rush for it! 👏
سلمان نور الدين
سلمان نور الدين2023-04-01 04:25
Could you provide more context or details about the issue you're facing so I can help translate it appropriately?
أحمد عين
أحمد عين2023-03-12 17:41
It's normal, just replace the electronic steering.
Can the Acura MDX have a four-wheel alignment done?
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
How to fix the steering wheel pulling to the right?
Hey car enthusiasts, does your KIA Pegas have the rear end wiggle when going over speed bumps or uneven roads while turning? My car is pretty stable at 120 on the highway, but when taking a turn and encountering such conditions, the rear seems to wiggle a bit. I've done the wheel alignment, but it doesn't seem to help.
After replacing the front suspension arms on my 2014 compact car, the steering wheel feels much lighter and not as stable as before. I took it to a repair shop, and they changed the valve core, saying it was a tire pressure issue. However, the light steering feel returned shortly after. I've already done wheel alignment and balancing, but haven't changed the power steering fluid. What could be the reason for this?
I bought it last month, and now the steering wheel pulls to the right while driving straight. Has anyone else encountered this issue?
Hey Lexus RX owners, does your RX pull the steering wheel on roads with ruts? My 2016 model pulls the steering wheel a lot, it's really annoying.
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
The steering wheel is crooked 🤦‍♂️. Even after doing a wheel alignment, it can't be fixed. The mechanic said it's caused by a deformed lower control arm?
Toyota Toyota Land Cruiser
Toyota Land CruiserAED 215,900 ~ 412,900Diesel & Gasoline
