Has anyone ever changed the hydraulic oil for the chassis lift on an LC100 4700? How do you replace it?
Has anyone ever replaced the rear wheel bearing on Xiaoya?
Has anyone here ever replaced a transmission? What issues can get you a warranty for the transmission?
How do you guys change the transmission oil, gravity or circulation?
4Hi everyone, after disassembling and reassembling the intake pipe, the idle is shaking, any idea why? It's an LC100, 4700. I disassembled the intake pipe when replacing the silicone oil fan coupler, and after assembling it, the idle has been shaking. Could it be sabotage?
5Have you ever tried running 12,000 kilometers before changing the engine oil?
6How is this brand A engine oil? Has anyone used it? How many kilometers do you change it?
7Has anyone ever changed the hydraulic oil for the chassis lift on an LC100 4700? How do you replace it?
8Do you guys often scrape the chassis when driving? Is it necessary to choose a front axle lift?
9Has anyone changed their transmission oil? How many liters did you use, and did you do a gravity change or a complete flush?
10Has anyone replaced the hydraulic struts for the trunk?
