محمد بارزاني
2023-01-24 12:07
Who has a complete picture of the engine bay fuse box? Mine is not clear, and I think the headlight fuse is blown. It's not working, urgent!
Who has the diagram for the driver's side fuse box of the Cowin X3?
Are there any fellow car owners who have installed a dashcam? I bought one, but the 4S shop said they don't know how to install it. Just wondering, does the BRZ only have the fuse box in the engine compartment? How do you all get the power?
Hey folks, are your car lights bright enough? I'm thinking about changing mine because they don't seem bright, but it looks like I have to remove the entire headlight to do it. Has anyone done this before? Any advice?
I've been driving a Suzuki SX4 for over ten years, and now the fuel consumption is higher than before. When I press the accelerator, the RPM goes up, but the speed doesn't increase. I've changed the transmission oil, cleared the engine carbon deposits, and worked on the throttle and fuel injectors, but the RPM is still high while acceleration is slow. Are there any fellow car owners who have experienced similar issues?
Why is there a buzzing sound coming from the fuse box and then the headlights turn on and the wipers work by themselves?
To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
Why isn't the left side of the lights on my Kia Cerato working when I lock the car? Is it a blown fuse or a burnt-out bulb?
Is the left front and rear lock lights of the Kia Cerato not working because the bulb is broken, or is it a blown fuse? Does anyone know?
