The fuel gauge doesn't return to the lowest point when the vehicle is turned off, making it impossible to check the fuel consumption.
What is the fuel consumption of an automatic transmission vehicle in the city?
Where does the temperature gauge on your Sportage point to? Mine is always about one notch below the middle. Also, for the manual transmission, the fuel consumption is 11 liters. How about yours?
How to check the average fuel consumption on the S5?
4The fuel gauge doesn't return to the lowest point when the vehicle is turned off, making it impossible to check the fuel consumption.
5What could be the issue if the fuel gauge is empty, you fill up the tank, and it still doesn't respond?
6Hey guys, how many percentage points can we get off the Macan at the lowest now?
7What's going on, does anyone know? The gear makes noise and the key doesn't return. Thanks.
8Where to check the water temperature gauge in a hybrid vehicle? 😂😂
9How to check the average fuel consumption of a manual Santana?
10Hey guys, where can I check the fuel consumption?
