Should I replace the brake pads with better ones or go for the original ones? What brands do you guys usually choose?
Are you guys replacing your Yige's tires with the original ones or going for other brands?
What should I pay attention to when maintaining a Vitara 1.4T automatic? Which brand of engine oil and filter is better? How often should the air conditioning filter be replaced? At how many kilometers should the original spark plugs and brake fluid be replaced, and what brand of battery is recommended to be replaced with?
4How many kilometers do you guys usually change your brake pads? Yesterday, during maintenance, the technician said the brake pads need to be replaced, but I've only driven 40,000 kilometers. Shouldn't need to change them yet, right?
5Which brand of brake pads is good for replacement?
6Hey guys, my 2014 Alto's coolant temperature doesn't go above 80 degrees. Is this normal? Should I replace the thermostat? Which one is better, the original or from Tenpu?
7How many kilometers should the brake pads be replaced on a Smart 453?
8What brand are the original brake pads, or can anyone recommend a good type of brake pads? Thanks!
9Is it better to buy Cayenne brake pads online or go to the 4S shop?
10Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
