What causes the engine oil level to increase in the SsangYong Korando diesel version?
What type of wipers can be used for the SsangYong Korando? They often leave streaks.
What type of coolant should be used for a 2014 Korando with a 2.0 gasoline engine?
The diesel version of the Hilux with a "G" typically indicates a 2.8-liter engine displacement.
4Korando diesel oil increase
5What engine oil do you all use for diesel versions?
6Can someone please send me the model numbers for the oil filter and diesel filter for the 60 diesel version? Also, does anyone have recommendations for the best oil? Thanks a lot!
7What causes the engine oil level to increase in the SsangYong Korando diesel version?
8For the 2016 Vitara automatic two-wheel drive Elite version, it's generally recommended to use 5W-30 engine oil. If you just changed the oil and noticed a one-liter increase in fuel consumption, it might be worth checking if the oil type and specifications are correct for your engine.
9What brand of engine oil is recommended for the 17 Middle East version of the FJ?
10Will the new 212 have a diesel engine version? Will there be a pickup version in the future?
