The noise level is too high when driving the 2014 4WD at high speeds.
Is the engine RPM high when driving at high speeds with the Ousheng 2.0 5-speed?
Hi everyone, for the 2021 Toyota Land Cruiser Prado LTD, how do you switch between high-speed 4WD and low-speed 4WD? When driving in full-time 4WD, do I need to come to a complete stop to switch between high and low-speed 4WD? Thanks!!
How to deal with loud noise at high speed?
4Is the car noisy when driving at high speeds?
5When driving at high speed in the 2020 top-spec Legacy, I notice the suspension makes a "gugu" noise. I'm curious if others have experienced this as well.
6How can I adjust the steering wheel weight on the Tucson L? The steering wheel feels too light and a bit wobbly when driving at high speeds.
7When driving a Vitara 4WD at high speed and braking, do you experience feedback or a pulsation in the brake pedal?
8When driving at 140 on the highway, is the noise level high?
9Is there a good solution for reducing the noise when driving at high speeds in the 2024 extended model?
10How's the noise level in the Touareg while driving?
