Thank you very much for the answers from the three experts. I changed the oil a few days ago, so it's not an oil problem. The issue now is that the RPM is high when in automatic mode, and stepping on the accelerator doesn't increase speed. There's always the sound of revving, but I can't just floor it. I have to switch to manual. In manual mode, the gear displayed on the center console is too low. When driving at 90 km/h on the highway, sometimes it's in fourth gear, sometimes in fifth. On my way to work, there aren't any steep inclines or declines, so I can't keep switching between automatic and manual. I'm busy with work and can't stop driving. Sigh...
How to switch from manual to automatic mode while driving a McLaren 720?
How to switch the McLaren P1 to manual mode?
The suspension adjustment on the Phaeton works well in just one mode, but when switched to other modes like Comfort or Sport, the soft and hard adjustment light stays on.
4When using the paddle shift manual mode in the HS with the S gear, do I need to press the brake pedal to change gears? In the past, when I drove a fully manual transmission, there was a clutch pedal. [Facepalm][Facepalm][Facepalm][Facepalm]
5I'm torn about deciding on the SP version. I saw a test drive review saying you can't always use the Plaid mode, so what's the acceleration like in the normal mode?
6Does the 2014 model have X-Mode? Why can't I find the switch?
7This morning I noticed that there are only 7 gears in manual mode, what's going on?
8How many liters of gear oil does a JETOUR X70 manual transmission require?
9The start-stop switch sometimes works, sometimes doesn't.
10Why does the economy mode in the Tanlu need to be set manually every time, and after turning off the engine and restarting, it automatically switches back to the standard mode? It seems like it can't be configured.
