حسين أنور
2019-09-26 07:44
عبدالله عيسى
عبدالله عيسى2019-09-26 09:54
There are basically two main reasons for insufficient cylinder pressure. The first one is what you mentioned: valve leakage. This is relatively easier to fix, as you just need to lift the cylinder head without having to remove the entire engine. However, if it's due to piston rings or cylinder wall wear, then unfortunately, you'll have to disassemble the engine for repairs.
Which is better for SsangYong Korando engine oil, Mobil 1 or Kunlun KR9?
What should I do if my 2010 Opel Astra GTC 1.8L has a cylinder misfire?
Does your engine cylinder head leak oil?
I've got a 2013 Kia Sportage Manual GL 2.0, and the steering wheel shakes when idling. I've cleaned the carbon buildup in the engine cylinders, the injectors, and the idle valve. I also replaced the spark plugs and engine mounts last year. Any experts out there have any advice?
Do I need to modify anything for the wiring when swapping a 1.8 engine into a Classic Fengfan 1.5, or is it a straightforward swap?
17 Leading Edition... 220,000 km driven. The engine cylinder head is damaged, causing water leakage. Has any other owner encountered the same issue?
Where can I buy a single fuel injector for the RDX 2.0T engine?
My engine has cylinder scoring after 9 years, what should I do?
