I have a 2011 SsangYong Korando, 2.0T, two-wheel drive version. When idling while parked or in drive, the car shakes and eventually stalls after a while. I've replaced the EGR valve, but it still shakes. Checked the fuel injectors, no error codes found. There's no SsangYong service center here anymore, and I'm really stressed out. Desperately seeking help!
Comments( 8 )
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
Today, my car sometimes shakes while driving. It shakes for about 2 minutes and then goes back to normal. Anyone know what the issue might be? Thanks in advance!
4My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
5What could be causing the steering wheel of my 2009 Lancer Sport to shake left and right while driving normally?
6I've got a 2013 Kia Sportage Manual GL 2.0, and the steering wheel shakes when idling. I've cleaned the carbon buildup in the engine cylinders, the injectors, and the idle valve. I also replaced the spark plugs and engine mounts last year. Any experts out there have any advice?
7Hey car enthusiasts, when I put my 4WD on a lift, the front wheels spin but the rear ones don't. After a while, it shows a "4WD Overheat" warning. But when I drive on the road for a bit, the error code disappears.
8Why is my vehicle shaking a little while driving?
9If your 2010 Suzuki Swift 1.5 automatic is still shaking after replacing the spark plugs, ignition coils, PCV valve, and EGR valve, there could be other issues at play. Some potential causes could be: - Engine mounts: Worn or damaged engine mounts can cause vibrations. - Fuel injectors: Clogged or malfunctioning fuel injectors can lead to engine misfires. - Throttle body: A dirty or faulty throttle body can affect engine performance. - Air intake system: Check for any leaks or blockages in the air intake system. - Transmission issues: Problems with the transmission can also cause vibrations. You may want to consult a professional mechanic to diagnose the issue more accurately.
10Hey car enthusiasts, has anyone experienced shaking during sudden acceleration? It shakes after driving steadily for a while, especially noticeable at high speeds. The 4S shop only cleared the previous driving habits, which improved slightly but didn't solve the root problem.
