Does anyone know how often the transmission oil should be changed for a gasoline Korando?
I have a 2014 Korando 2.0 petrol 4WD luxury version. Could you please tell me how often or after how many kilometers I should change the transmission fluid? Thanks!
How many liters of transmission oil does the GA8 need to change? Should it be by gravity?
4How often should the gear oil be changed for the Rapid?
5How often should differential oil be changed?
6How often should the transmission fluid be changed?
7How often should transmission fluid be changed?
8How often should the transmission oil be changed?
9What type of engine oil do people generally use for a newly purchased second-hand 2008 2.0? How often should the transmission oil be changed? Thanks!
10How many kilometers should you typically change the transmission oil?
