What could cause a loud banging sound when I shift gears after the car has been parked overnight?
What could be causing a buzzing or hissing sound in a 2016 Volkswagen Phaeton V6 both when parked and driving, and how can it be fixed?
Hi everyone, I need some advice. I bought a second-hand 2017 F150 XLT model, not sure from which country. Here's the issue: No matter what the setting is, when I shift gears, the low beam lights turn on. If I turn off all the lights, the daytime running lights don't come on, but when I shift gears, the low beam lights turn on. When the automatic headlight setting is on, the daytime running lights come on, and in park mode, the low beam lights don't turn on, but after shifting gears, they do. I'm wondering what could be causing this and if there's a solution?
I have a manual 1.3 model from 2011. It's difficult to shift from first to second gear, and there's a loud gear noise. What could be the issue?
4What causes difficulty in shifting gears in a manual transmission? Has anyone experienced this?
5The Kia Sportage has a jerking sensation when shifting gears.
6I have a Maserati Quattroporte. Recently, when parked under the sun, the AC blows hot air, but after parking overnight in the garage, it works fine again. This keeps happening repeatedly. Does anyone know what might be the cause?
7What could be the reason for not being able to shift gears when the car is cold?
8After turning the key, it doesn't spring back, and there is a squeaking sound when shifting gears. What could be the issue?
9What could cause a loud banging sound when I shift gears after the car has been parked overnight?
10When shifting from D to neutral, there is a clicking sound. What could be the problem?
