سعود أشرف
2024-05-11 14:28
Hey guys, I have a 2019 Kicks. When I'm waiting at a red light and switch to N gear, then back to D, the acceleration feels noticeably slower. Has anyone else experienced this?
طيب نايف
طيب نايف2024-06-27 16:03
There's no point in shifting to neutral at a traffic light with a CVT, right?
عبد العزيز أنيس
عبد العزيز أنيس2024-05-11 23:29
Switch back to D gear, wait for 3 seconds, and then accelerate.
I need help from everyone. When shifting from neutral to D gear, there's a noticeable jolt. What's causing this issue? Thanks a lot!
Registered in November 2015, 1.5T Luxury version, driven 100,000 km. Recently, when accelerating a bit too hard, it feels like it shifts to neutral; the engine revs, but the dashboard still shows D gear. If I release the gas pedal and wait for a second or two, then accelerate slowly, it goes back to normal. I can't accelerate suddenly, only gradually. Has anyone else experienced this problem? It's been repaired several times but still not resolved.
Fault code P0504, currently gears 1, 2, 3 are fine, but when switching to 4th gear, the car loses power when pressing the accelerator and doesn't accelerate. The RPM drops very slowly when pressing the clutch. Has anyone else experienced this?
When the old model Vito is at a red light and you shift from N to D, causing the car to lurch forward, what could be the reason?
Car enthusiasts: Can you please advise, do you have to be in the P gear when turning off the engine for the Changan? Can you park and turn off the engine in the N gear and then switch to P gear? Thanks!
Is it normal that after switching from the original 19-inch wheels to the 21-inch ones that came with my 2024 Panamera, the ride feels less smooth and acceleration seems slower?
Hey car enthusiasts, quick question. When I switch from N to D while idling and press the brake, the car jerks a bit. It's a new car, is this normal?
Nissan Nissan Kicks
Nissan KicksAED 61,900 ~ 89,500Hybrid & Petrol
