عبدالرحمن أمين
2024-07-18 00:14
Where is the oxygen sensor located in a KAMIQ?
Where is the USB port located?
Where is the radiator located?
Is it necessary to replace the sensor if there's an oxygen sensor 2 circuit fault?
4The fault code shows two P0420s, one yellow and one red, both indicating the first bank. Is it the catalytic converter that's faulty or the oxygen sensor?
5Where is the MG GS outdoor temperature sensor located?
6Where is the key sensor for the GA8 located?
7Where is the car key sensor located?
8The automatic headlight sensor in the Nissan Patrol is typically located on the dashboard, near the windshield.
9Where is the oxygen sensor located in a KAMIQ?
10Where is the fuse box in the Kamiq?
