خالد حارث
2024-08-01 14:18
When driving the Kamiq, if a red "P" appears on the dashboard and there's a beeping sound similar to the seatbelt alert, what could be the issue? Can anyone advise? Thanks!!
Guys, today I tried flooring it in Sport+ mode and heard a rustling sound that lasted about 5 seconds before disappearing. No error codes on the dashboard, and the car drives fine. However, when I parked and shifted to P, there was a continuous electrical noise. The noise disappeared after switching to neutral and back to P. Could there be an issue with the transmission? How should I check it?
Hey folks, I have a 2012 Grand Cherokee 5.7. Recently, the sound for the steering alert, seatbelt alert, and radar alert has disappeared. I guess it's probably an issue with the buzzer. But where is this buzzer located?
Whenever I used to brake, my Land Cruiser would occasionally emit a beeping sound, similar to the reverse radar sound. Recently, it happens every time I brake. Does anyone know what the issue might be?
Car enthusiasts: Can you please advise, do you have to be in the P gear when turning off the engine for the Changan? Can you park and turn off the engine in the N gear and then switch to P gear? Thanks!
When the trunk of the Peugeot 301 is opened and then closed, the dashboard makes a ticking sound, similar to the sound of hazard lights. Does anyone know why this happens?
When the car is moving, there's a beeping sound. The seatbelt, fuel, and camera are all fine, and it's not the collision warning. Does anyone know what could be the reason?
I have a question for everyone. Occasionally, when opening the door of my 2021 Subaru Outback, the hazard lights flash a few times accompanied by a beeping sound, then it disappears. There's no indicator light on the dashboard, and there's no issue while driving. What could be the reason for this? I've been driving it for a few years and it's the first time I've encountered this situation.
While driving the KAMIQ, a red "P" appears on the dashboard, accompanied by a beeping sound similar to the seatbelt warning. What could be the issue? Thank you!
Sometimes, when I start my KAMIQ, a wrench icon appears with the ABS anti-skid warning. The car shakes as if it's not getting enough fuel. But when I turn it off and restart, it's fine. Can any experts advise?
